movies on wii?
Discussion in 'Nintendo Wii-U & 3DS' started by avnutter, Apr 29, 2007.
  1. avnutter
    avnutter
    Feb 7, 2005
    1,569
    west yorkshire
    +184
    hey guys, where do i play movies on the wii?
    i have movies from a sony t50 camera which i put on the sd card, i can access the pics but no sign of any moves.
    thanks in advance.:thumbsup:
  2. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,916
    Nottingham
    +400
    You need to convert your video into the JPEG Motion format the Wii recognises through something like this - http://www.squared5.com/
    btw I've tried it, it works for my Mac.
  3. avnutter
    avnutter
    Feb 7, 2005
    1,569
    west yorkshire
    +184
    downloaded the software but having trouble.
    do i click on convert? if so what am i converting to?
    thanks.
  4. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,916
    Nottingham
    +400
    I'm using a Mac so there may be differences but firstly I load up the movie to be converted then go to 'Export to Quicktime' - File menu, from there I choose 'Apple Motion JPEG' A/B both seem to work, all the settings you can leave but I found for best resolution in the correct format I change frame size to 640X480, then just go to Make movie & the movie should be converted to play on the Wii via the SD card. Good Luck! :smashin:
  5. avnutter
    avnutter
    Feb 7, 2005
    1,569
    west yorkshire
    +184
    sorted.:thumbsup:
    nice one fella.:clap:
