Movies on SPV?
Discussion in 'Mobile Phones Forum' started by Oblivion, Jun 20, 2003.
  1. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Does anyone here think it would be possible to play an entire film from a 128Mb SD card?
    Paul
  2. Lukeymac
    Lukeymac
    Nov 18, 2002
    104
    +6
    I had total recall on mine the other day. After it was compressed down in size it was only 40mb. An episode of friends compresses down to about 10 megs. So yes it is possible. Be careful though, because unless you use some new software or write an asx, then you will have problems restarting it in the same place after a phonecall or text etc. A div x player is also now available although I haven't tried this yet
