Movies discovery service in mce2005 for the UK
Discussion in 'Microsoft Windows' started by Werner, Mar 13, 2005.
  1. Werner
    Werner
    *****THIS WILL BREAK YOUR MCE INTERFACE UNTIL I GET MORE HELP WITH VISUAL STUDIO.NET****
    Well, in one of the more popular threads it was asked if we could have the movies part showing as the third icon for mce2005 under the "my tv" option. Currently, this part (discovery service) is only available if your mce2005 machine is in the states or canada.
    http://htpcnews.com/images/mce2k5/home.jpg is an example of the bit I am talking about
    I have some success with this, and would hope to explain what I did and where I need some help now. This is a private thing and may possibly bork your computer totally.
    Firstly, you need resource hacker. Or any other winPE resource editor. Open the file ehshell.exe in c:\windows\ehome
    Browse with your resource editor to the only xml file you find (in resource hacker it wa sunder 23/neutralstrings.xml/1033
    Go to the last few lines, find this part
    <string id="Discovery.Supported.CA" value="true"
    and change to <string id="Discovery.Supported.GB" value="true"
    Now, discovery service is available to USA and GB, instead of USA and CA
    Ok, now, the file has changed, so system file protection will kick in. Dont bother with all the registry hacks, just go to c:\windows\system32\restore open filelist.xml and add this line to the <exclude> section near the very top
    <REC>%windir%\ehome</REC>
    this wil make file protection not care about the ehome directory.
    Now, save your new ehshell.exe file to c:\windows\ehome as well as to c:\windows\system32\dllcache
    Within a few seconds windows will prompt to overwrite the file, select "cancel". It will then ask if you want to keep the file, select "yes"
    Double click ehshell.exe or start mce shell, and, hopefully, your machine should spit out an error message about strong name validation. If this happens then you have done the correct thing. Try start it again, the error should persist. If it doesnt then that means you havent turned turned off file protection for the ehome directory, or havent replaced the copy in dllcache and windows has replaced the "changed" file with a pristine version.
    The error occurs because ehshell.exe is signed, and checks the signature when it starts up, and because we have modified it the signature is no longer valid.
    TO DO: find some kind soul with visual studio.net2003 to follow these instructions
    http://www.codeproject.com/dotnet/NeCoder03.asp
    to remove the signature checking to make sure we now have the third icon.
    :thumbsup: :thumbsup: :thumbsup: :thumbsup:
  2. mclay
    mclay
    Mar 3, 2005
    74
    good post! I am a software developer for a living and will give this a look.... will post when i have a result....
  3. mclay
    mclay
    Mar 3, 2005
    74
    had another look at the codeproject link... this can be achieved with the .net SDK as well if anyone else is having a go.
  4. Werner
    Werner
    I just tried with the sdk
    I got my ehshell.il compiled again using ilasm, but the resulting exe file errors out quite badly. Damn tired right now, plus I'm not a programmer by nature, so just figure things out....I will leave this to you experts...the seeds have been planted though:)
  5. mclay
    mclay
    Mar 3, 2005
    74
    hi werner,do u use IM like msn?
  6. Werner
    Werner
    well, I found this post on tgb
    http://www.thegreenbutton.com/community/shwmessage.aspx?ForumID=27&MessageID=78447&TopicPage=1
    followed the instructions for changing ehshell.exe but either
    1) I am thick (VERY possible)
    2) I am using the wrong sdk (1.0a wont install on my system here)
    3) it is past my bedtime
    but I cant get it to work. I compile my ehshell.exe and it generates errors on executing. I have found (on my system) that if ehshell.exe is not in the windows\ehome directory I get an error, but it isnt helping me right now...too much of a long day.
    A tip, if you use ldasm, and go file-->dump it will dump an *.il and a *.res. Best plan of attack I can think of is open *.il in wordpad, edit out the "hash algorithms" part. Open *.res in resource hacker, change the xml file, compile, save
    Then, use ilasm as in
    ilasm.exe /resource:ehshell.res /exe ehshell.il
    this creates a valid pe executable, with the correct mce icon, but still errors.
    Yes, I have msn messenger
    pm me your msn addy and I can add you...two heads work better than one etc etc etc.
  7. Werner
    Werner
    well, I finially got it compiled again, but still no thrid icon...bang goes that idea...
  8. mclay
    mclay
    Mar 3, 2005
    74
    ouch (given the time) :)
    was a very impressive attempt!
  9. Werner
    Werner
    scratch everything above, found an easier way, courtesy of another forum
    You need to change language settings to US by going into Control Panel > Regional and Language Settings > Languages Tab > Details Button and change default input language to United States
    Then we need to fool PC into using UK Keyboard layout under the United States as Langauge....
    The registry keys below will change to US 409 codepage BUT will retain UK keyboard layout as the UK DLL will be loaded instead of the US one meaning your keys are properly mapped!
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layouts\00000409]
    "Layout File"="KBDUK.DLL"
    "Layout Text"="United Kingdom"
    "Layout Display Name"="@%SystemRoot%\\system32\\input.dll,-5000"
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout\DosKeybCodes]
    "00000409"="uk"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Media Center\Settings\MCE.GlobalSettings]
    "systemGeoISO2"="US"
    voila! now I have a movies icon
  10. mclay
    mclay
    Mar 3, 2005
    74
    excellent..... didnt quite work for me... seems too easy to get something wrong! lol...
  11. Werner
    Werner
    just follow the steps one by one. The important part is the bit about control panel....that will activate the movie icon (as well as the registry change to geoiso2)
    The rest of the changes is to ensure the keyboard remains a uk layout, even though you have selected US. They wil only take effect after a reboot
  12. mclay
    mclay
    Mar 3, 2005
    74
    lol ok i get it, changed the registry, and the settings, and windows changed it back. lol Ill keep at it!
  13. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    Werner you are a genius or at least whoever worked this out is/was.
    Works like a dream here..
    Manty thanks
    Chris
  14. mclay
    mclay
    Mar 3, 2005
    74
    did you guys delete the UK entry under the keyboard layouts so ther is only one to choose? Can I assume the locale of your pc is still UK?
    sorry to sound so blinkin thick, but I changed all of these and the registry just resets itself, can only think that there is something else that I have set somewhere.
    Matt
  15. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    It worked exactly as Werner says using Regedit and only copying the text between the quotes.
    So far the thumbnails are not loading in the guide (I assume these do in the US) but the information is correct for UK including genres etc. One of the hidden parts of MCE 2005 I particular wanted.
  16. CTID
    CTID
    Dec 28, 2003
    747
    Far, Far Away
    +16
    excellent work werner - much appreciated. I can't wait to try this tonight. BTW what was the other forum?
  17. Werner
    Werner
    the thumbnails work fine if you select to view actors, etc. If you just click on what movies are on now or next, I dont get thumbnails either.
    the other forum was a bit of a search through www.thegreenbutton.com to put two and two together. I posted my original decompiling thoughts there, and got some clues from responses.
    To be honest, I really like the movie service, it's almost like browsing the web in that each actor can be linked to another actor viw 3 steps etc etc (or whatever that theory is). You can pull up a movie, view the actors details, view other movies by the actor, then maybe find on eyou like, so you select "view similar movies" and I can spend hours just reading up on movies I never knew existed.
    2 THUMBS UP
    :thumbsup:
  18. CTID
    CTID
    Dec 28, 2003
    747
    Far, Far Away
    +16
    ahh, that'll be the Kevin Bacon game. Any actor can be linked to another via Kevin Bacon by 6 connections, as Kevin Bacon is the centre of the entertainment universe :)
  19. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    It is really wierd why Microsoft do not offer this as default in the UK I assume it is a copyright issue.
    After a morning playing it really is one hell of a toy if you are a movie fan - makes having terminal flu quite bareable.
  20. mclay
    mclay
    Mar 3, 2005
    74
    big movie fan here.... :( going to have another stab at this later!
  21. mclay
    mclay
    Mar 3, 2005
    74
    ok i got it... lol wasnt me being thick (im sure!). It didnt seem to be applying the reg change. I exported the key, edited that and then reapplied it. voila!
    Thanks werner.... i am the biggest movie fan!
  22. Kramer
    Kramer
    Working here too.
    Good work :smashin: .
  23. gweilo
    gweilo
    So close - can see the movies icon but keyboard thinks it's US...
  24. Werner
    Werner
    reboot for keyboard changes to take effect
  25. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,236
    116
    The Apps are Calling :-S
    +495
    I've been trying to get this to work, but no joy.
    I've checked and re-checked all the changes that needed to be made, and they are. The keyboard is set to US, but acting like a UK one, so that all seems ok. But no new icon has appeared, nada, nothing, zip, zlich . . . . . . :mad:
    Anyone got any ideas??
    Giz.
  26. PaulBS
    PaulBS
    Hi all,
    Works fine, no probs. Great work Werner. :clap:
    Paul
  27. mclay
    mclay
    Mar 3, 2005
    74
    Giz,
    I would export the correct key, edit the export, and then double click the new file. Thats how I got it to work....
  28. Dave_M
    Dave_M
    Jan 31, 2005
    54
    Harrow
    I had this working fine, but then reinstalled MCE and applied the patch again.
    Now it kind of works, but I get error messages saying that 'Automatic Download' is not enabled, so it won't show some of the information - and restricts itself to films that are in the guide.
    Any ideas?
  29. Werner
    Werner
    Long shot here, but perhaps it's got something to do with your internet connection setup within MCe.
    Part of the first time wizard is to ask you what type of internet connection you have, where you can select always on, manual downlaod, or downlaod when connected. Sounds like you need to go investigate that menu....maybe under settings-->general (although I dont have an mce machine nearby to confirm)
  30. cbemoore
    cbemoore
    May 16, 2002
    1,300
    38
    Esher
    +16
    Thanks to Werner's posts on this thread, I've managed to enable the Movie Browser and I couldn't be without it now! Thanks Werner!
    But one thing still annoys me. When I browse to a movie and display the movie info, only the first few lines of the movie summary are displayed. Is there any way to display the complete summary? I've tried everything and I'm running out of ideas....
    Chris
