MovieFactory HG10 Query
cogla
When using Ulead DVD MovieFactory to download clips from my Canon HG10 I get the message
'The data rate exceeds the specified value. Continue saving?'
Am I doing something wrong ?
senu
Which version are you using?..The one that comes with it is OK but the Version 6 plus is better
Are you doing something wrong? Probably not
senu
The video doent look that bad TBH ;)
Apart from compatibility with the clips, the supplied software is a bit basic though
The "newer" Version 6 Plus would seem to be better . I have it but haven't used it for clips from the HG10 ( which has now gone back to Canon it was on loan fro trial purposes): I do have clips I could try with it if you wish
Sony Vegas MS8 Platinum is fab but AFAIK currently has limited output option to AVCHD .
Otherwise It is money well spent.
Nero vision 5 ( Part of Nero 8) is surprisingly good
I could give the Full version of MF6 plus a go and se if I will reproduce the "problem" but TBH Ive used Sony Vegas and Nero respectively without any Problems
As you know They all have trial versions
