Movie software for netbook
Oldi
I am in the process of putting some VOB file movies onto a netbook but cannot play them. I have also put Nero 9 on but it will only play the files after a trial download is loaded, then need to pay to upgrade the software.
Is there a free application to play films please? As usual, left this to the last minute and now in a rush to sort it out...
Thanks.
next010
MPC-HC or XBMC are other options too all free.
If ripping vob files it's best to rip to a self contained .iso image of the disc (most DVD rippers support this), that ensures better compatibility with media players as not all players handle reading the raw files from a DVD in a folder well.
Oldi
Thanks for the tip, I use DVDFab to backup DVD's. I began to try their Rip feature but it displayed a total of 3hrs so abandoned it, is there another better solution (preferably free/cheap as I will not use it much)?
