Movie Posters
Discussion in 'TV Show Forum' started by videonastie, Jun 3, 2003.
  1. videonastie
    videonastie
    I know this has nothing to do with movies, but I have a few decent UK Quads (40" x 30") that I want to frame, but I'm having a problem trying to find a store that sells frames for this size. Does anyone know of any sites or shops that stock anything like this?:D
  2. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    They are very difficult to find frames for. Ive had mine custom made i got them done by www.atthemovies.co.uk they are expensive but look great.
  3. CarlB
    CarlB
    Jan 8, 2001
    1,110
    Godmanchester, Cambs
    +96
    Or buy a larger frame then have a custom mountboard cut at your local art supplies shop. We have a gallery nearby and they can cut mountboard at any conceivable size, so I got nice charcoal mounts for my posters and they look much better than if they were in the frame alone.
  4. videonastie
    videonastie
    I'm looking for an aluminum frame?
  5. neilo
    neilo
    Apr 18, 2002
    1,564
    38
    +21
  6. adieacc
    adieacc
    Feb 2, 2002
    128
    16
    South Wales
    Have you tried
    www.fastframes.co.uk
    I used them a couple of weeks ago, admittedly for smaller frames (70 x 100) but found them good quality and quick delivery,
    Adieacc
  7. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    I colect vintage movie posters and after 10 years I still haven't found an off the shelf frame. Best bet is to shop around and look for bulk discount from local framers. Don't dry mount whatever you do tho!!!
    Mike
  8. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    'dry mount' explain please and why not?
  9. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    Basically it depends on the value of your poster (or projected value). Dry mounting (i.er glueing of poster to a backing to remove creases) destroys any residual poster value. I have stuff like Raging Bull and Jaws originals which sell for £100's but would be worth nought if dry mounted. If you are talking about contemporary blockbusters not so much of a worry - though original Episode 1 and Matrix can already fetch a tidy sum. Drop me a PM with your titles and I can give you an approx value.
  10. shaunthedude
    shaunthedude
    Yip, follow Tullamores advice. Im a collector too and have some rare titles (Hell Drivers, Ice Cold in Alex, Bullitt quads) I have some in a clip frame which i had custom made at a framers shop. Cost £40 but looks good
    shaun
  11. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    I've linen mounted or paper backed quite a few (conservation techniques - £££££!!!!!). I wouldn't suggest doing it on the one we talked about James 45. It will be fine as discussed. Of course then you need an even bigger frame! Anyone recc'd a good site (other than eBay) to sell some - Mods - if this was an out of order question..sorry!
  12. shaunthedude
    shaunthedude
    sell some what???
    posters?
    shaun
  13. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    Hi Shaun,
    Sorry - yes posters.
    Mike
  14. shaunthedude
    shaunthedude
    ive used mainly E Bay. Greg edwards somtimes buys if they are rare or dave and Pat cutts will take them.
    saun
  15. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    Usual suspects TBH. Thanks anyway. Looks like i'm on eBay next month.
  16. shaunthedude
    shaunthedude
    which ones are you selling. What are you into.
    shaun
  17. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    I'll PM you before we get modded.
  18. James45
    James45
    Sep 21, 2002
    2,844
    59
    Has anyone been PM-ing as me? Cos I only made the one post on this thread. Tullamore how much are original Jaws quads going for?
  19. tullamore
    tullamore
    May 14, 2003
    268
    Surrey
    +3
    It's a Jaws US 1 sheet which is a little bit smaller than a quad and vertical rather than horiz. It's folded and has a minor blue spot on the bottom so would need pro backing if you wanted the creases out. Looking for around £350. It goes for much more at auction houses and the main London dealer Reel Poster Gallery is selling a linen backed copy (lin or paper backing costs around £60) at £500
    http://www.reelposter.com
  20. James45
    James45
    Sep 21, 2002
    2,844
    59
    one day maybe then, that would be a quality item to finish off a home cinema
