Movie Poster frames
Discussion in 'TV Show Forum' started by videonasty, Sep 20, 2004.
  1. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
    I have no idea whether this is in the correct forum, but. Can anyone recommend a site that stocks good quality/good priced poster frames for UK Quads (30" x 40") & US 1 sheets? (27" x 41") :confused: :thumbsup:
  2. smartiepants
    smartiepants
    Jan 22, 2004
    219
    +9
    I don't know about online sites but I have got frames for movie posters from Ikea for about £25/30 they have perspex instead of glass but look fine :thumbsup:
  3. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
    I saw them on their site, but their sizes are strange?
    CHEERS
  4. smartiepants
    smartiepants
    Jan 22, 2004
    219
    +9
    I think they are labeled up at 100cm x 70cm
    this converts to 39.37in x 27.55in
  5. captainH
    captainH
    Mar 17, 2004
    902
    63
    Bucks
    +255
    You could also try Cargo - again these are very large perspex but I prefer this as when I bought very large glass frames from John Lewis they were cracked by the time I got them home....useless!
  6. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    The Ikea ones are too small for proper movie posters, but good quality ones can be bought from moviemarket.co.uk
    I've bought from them and their frames aren't cheap, but they are very smart and of an excellent quality, as they are intended for cinema use.
  7. shaunthedude
    shaunthedude
    Terry at QUADBOD has some fantastic frames in. They are specialy for quad posters and allow you to change the poster when you want. Check them out here
    http://www.quadbod.co.uk/
    cheers
    shaun
  8. docsmith2k1
    docsmith2k1
    Apr 20, 2002
    520
    Liverpool
    +17
  9. sjp1966
    sjp1966
    Oct 29, 2003
    545
    Kent
    +10
    nice, but very expensive
  10. videonasty
    videonasty
    Feb 12, 2004
    2,274
    West Midlands
    +39
    Too expensive :rolleyes:
  11. sleepyone
    sleepyone
    Jun 4, 2003
    736
    Glasgow
    +17
  12. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
  13. sleepyone
    sleepyone
    Jun 4, 2003
    736
    Glasgow
    +17
    Glad I could help.
    Ordered a couple of clipframes and real glass certificate frames from them and they have all arrived intact, and unmarked. :thumbsup: for FastFrames
  14. shoestring25
    shoestring25
    Feb 2, 2003
    4,086
    essex
    +562
    i made my own. mdf backs, perspex front, clips to lock them togther and a hook for the back all cut to the exact size i wanted 27x40 and a few 30x40 worked out less than £7 each and they look brilliant. they needed to be cheap as i have about 30 of them throughout my house
  15. sleepyone
    sleepyone
    Jun 4, 2003
    736
    Glasgow
    +17
    If you had seen the state of the tent peg I made in high school, you would understand why I buy frames. :laugh:
  16. stevethone
    stevethone
    Sep 18, 2004
    424
    +5
    thought i'd give this thread a *bump*.
    I'm still looking for CHEAP frames for US 1 sheets (27x41inches), can anyone help me?
  17. ilovedts
    ilovedts
    Here's one. :D Does anyone know where you can get frames for Italian Posters, which measure in at 55" x 40" :confused: :suicide: :D
  18. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,575
    2
    In a secret location with Jennifer Lawrence
    +10,563
    Moving to Movies and TV forum. See if we get more replies there.
  19. shoestring25
    shoestring25
    Feb 2, 2003
    4,086
    essex
    +562
    but you wouldnt have to make them, get homebase to cut the mdf and perspex to size for you like i did. all you have to do them is assemble them.
    thats how to get cheap frames exactly the size you want. :thumbsup:
  20. Garrett
    Garrett
    Apr 21, 2001
    42,780
    2
    167
    The best thief you'll never see.
    +7,989
    I made my own as it had to go at the back of a book shelf. What I did was order some hardboard from a timber merchants the right size (swine cut it 3/16 of an inch short in one direction). Got some cellophane and covered it and held it in place with masking tape. Only cost me about £4.
