Movie Orientation (Quicktime)
Discussion in 'Photography Forums' started by blackstone, Mar 13, 2005.
  1. blackstone
    blackstone
    Oct 10, 2003
    127
    Glasgow
    +4
    I took several short movies using an Oly mju 410 and on play back they all look fine to a newbie like me. The problem is i have downloaded to my pc and some of them now have incorrect orientation. They play back on Quicktime format with no option that i can find to rotate. I tried to export to windows media player but just get a blank screen. Any advice appreciated. :)
  2. HMHB
    HMHB
    Nov 11, 2001
    27,517
    Nottinghamshire
    +6,438
    I rotated some of my AVI files using Windows Movie Maker which comes with XP, it gives you the option to rotate them around 90,180,270 degrees. I don't think that it will import .mov files unfortunately, so you may need to find a way of converting them into another format.
  3. blackstone
    blackstone
    Oct 10, 2003
    127
    Glasgow
    +4
    Thanks John, the other options would be to upgrade to Quick Time Pro or upgrade Camedia package that came with the camera. Will also try and see if I can find conversion plug in from AVI to .Mov
