Movie Maker 2 and sound capture
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by norfy, Oct 16, 2003.
  1. norfy
    norfy
    I have a Sony TRV33 and Windows Movie Maker 2 on my pc. I want to be able to capture just the sound from a video clip and turn it into an mp3. Is this possible ?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Capture the clip as normal in MM2 (sound & video) and save it to a folder on your HDD.
    Go into that folder from Windows and you will see 2 files. 1 will be the video and the other the WAV sound file.
    Open this file in any sound encoding prog and convert to MP3.
    MM2 will not AFAIK convert a WAV file to MP3.
    Mark.
