Movie conversion help required
Discussion in 'Blu-ray & DVD Players & Recorders' started by gwladok5, Jun 30, 2005.
  1. gwladok5
    gwladok5
    Dec 2, 2004
    181
    I'm using a RAM disc on my Panasonic DMR-E55 to capture a programme from my Sky+ box. I'm then editing the RAM disc on the recorder & want to write the finished programme to DVD via my PC.
    On the PC, the RAM disc shows a DVD_RTAV folder containing 3 files ie. VR_MANGR.BUP, VR_MANGR.IFO & VR_MOVIE.VRO
    Can anybody tell me if it is possible to convert these files to the standard AUDIO_TS & VIDEO_TS to enable me to create then play the DVD as normal?
  2. gwladok5
    gwladok5
    Dec 2, 2004
    181
    This is what happens when you dont read the threads properly!!
    I've now seen the posting below mine which is covering the same topic.
    I'm now going to read that!!
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,701
    Warwick
    +2,578
    gwladok5,
    Have a look at the 'DVD-RAM to DVD-R' link in my signature - that will guide you through the process of what you want to do. You clearly already have a RAM compatible PC drive and thus all you need is a programme such as TMPG Enc Author that will convert from VR to Video mode.
  4. gwladok5
    gwladok5
    Dec 2, 2004
    181
    Thanks Rasczak
    downloaded the TMPGEnc software & are now watching my first completed DVD!
    Thanks for your posting & support
