Moved the projector to ceiling, doh !
Discussion in 'Projectors, Screens & Video Processors' started by chriswhiteuk, Sep 21, 2004.
  1. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Hi all
    Moved the prohector with good and bad results . . .
    Good thing is I can now USE the room properly ! I was quite happy with it, dead aligned with screen on coffee table . . . until someone nearly knocked it into oblivion !
    I've now mounted the projector on the ceiling, but in order to get the picture on the screen (this can't be moved) I've had to use +15 on keystone :suicide: and now I'm sick as a dog.
    Anyone had experiences with tilting the screen ? Problem I have is the screen is pull down type, so would need to be under tension . . .
    Would moving to a projector with lenshift help matters ?
    Chris
  2. brain
    brain
    May 30, 2004
    67
    know how you feel...i still have mine on a table between the two sofas:
    [​IMG]
    this way i can have the keystone set to minimum levels so i can retain the ultra-sharp image...
  3. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    had to rub it in didn't ya !
    The Sanyo is more or less on par with the Panny ae500, you think it is worth looking into moving onto/swapping to this projector, or wait for the upcoming AE700 ?
    Someone want to lend me a Z2 ?
  4. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Just watched the video demonstrating the Lenshift on the Z2 ! that'd be IDEAL.
  5. nwgarratt
    nwgarratt
    May 5, 2002
    27,244
    +3,064
    Does using keystone really worsen the pictrue quality that much?
    I am using a PTAE100 on a keystone of +7 at the moment. This is because the screen is quite high.
    I was thinking of using a TV/video bracket on the wall to raise the projector more.
  6. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Definetaly worth getting the pj aligned with the screen without using keystone.
    It's such a waste of pixels (details) specially for me after getting a good DVD player to use !
  7. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Try this for fun... adjust the pj so that there's zero keystone, put on a dvd and freeze a frame with someones face in full shot, then start applying keystone adjustment, and watch the shape of the face distort - that's the picture degradation the keystone introduces.
    S.
  8. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Well after less than 48 hours, the PJ is back where it was . . .
    [​IMG]
    Sacrificing room usage for PQ !! Whatever next !
    :smashin:
  9. nwgarratt
    nwgarratt
    May 5, 2002
    27,244
    +3,064
    Nice photo. How far is the PJ away from the screen?
  10. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    about 2.5m if that . . .
    Can't find my blasted tape measure !
  11. wandgrudd
    wandgrudd
    Dec 16, 2002
    184
    Nottinghamshire
    +6
    brain
    why do you need to use keystone ?that looks like it would be fine with it mounted to the ceiling
  12. brain
    brain
    May 30, 2004
    67
    i didnt want to use a ceiling mound as I would need a longer cable...and more importantly...I live in a rented flat. I dont want to drill holes etc and I dont think the letting agency would like me doing that.
  13. nwgarratt
    nwgarratt
    May 5, 2002
    27,244
    +3,064
    Thanks for that.
    I have a widescreen TV about the same distance from the PJ. I decided to put the screen up over the TV but I am wondering if it is too high. The screen comes of the ceiling so it could be moved forward so it goes down about half way down the front of the TV. I was bothered that being about 2.5m would be too close. It would also mean no keystone though.
  14. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    264
    Surbiton
    +6
    Depends how big your screen is . . . 60" is edging on too big at my viewing distance (sit just behind the PJ).
    I was considering getting a 50" plasma, but I still don't like the pictures they produce.
    This is what mine is like when not watching the PJ :
    [​IMG]
    [​IMG]
