Moveable Front speaker
Discussion in 'Home Cinema Speakers' started by Dak, Aug 26, 2003.
  1. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    I have a pair of Linn keilidhs either side of a double doorway. I plan to have a scree and pj installed that comes down over the doorway so will need a centre speaker that I can lift in and out of the way as required.
    Any suggestions for one that is light enough to be moved but heavy enough to be good, match the Keilidhs and suchlike? Denon 3803 will be running them.
    Ta.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    If you picked up a Centrik you could always use it as a door stop. :)
    Can you go in-wall? If you can a Sekrit would be worth considering.
    The Trikan would also be a good match. It's not a silly weight or price, and is a very good speaker.
  3. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    I cannot do in wall unfortunately. My dealer says just to use a phantom centre but I have not been impressed with the way this sounds.
    I will also need a stand that is permanently attached to the centre speaker, do you know of anything that will fit with the trikan and stay attached?
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
  5. Dak
    Dak
    Sep 23, 2002
    251
    Chislehurst
    Thanks. It is all coming together!
