Question Move SuperHub3 Down stairs ??
Discussion in 'Networking & NAS' started by nyck, Dec 2, 2017.
Tags:
  1. nyck
    nyck
    May 2, 2003
    39
    Just upgraded to the virgin SH3 and V6 Tivo ,previously SH + tivo
    At present the the main cable is in my living room and splits for the Tivo and a coax going up stairs to the SH now SH3
    They recommend the new V6 Tivo should have a direct connection to the SH3 which is a issue as the moment as one is upstairs and the other is down in the living room .
    So im thinking of leaving the SH3 downstairs and using the existing coax that goes upstairs as draw wire to run a cat5 back up to my existing network switch.
    My only problem is that i really wanted all my the modems/switches/cables etc going back to one central point ,so if i have any internet issues i can look at one point or power cycle everything in one go
    cant decide
  2. mickevh
    mickevh
    Apr 30, 2007
    7,225
    West London
    +1,738
    If your SH is also functioning as a Wi-Fi Access Point, moving it will affect Wi-Fi coverage, which could be positive or negative - you won't know until you try it. If a move has detrimental effects, you could always use you old SH as an additional Wi-Fi Access Point if need be.
  3. nyck
    nyck
    May 2, 2003
    39
    Im doing a total upgrade ,i've bought 2x TP Link EAP225 for my wireless so the SH will only be Modem/router only
  4. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,320
    +1,278
    Reading the reason why it needs a connection is because the v6 doesn't have a cable modem built in any more so it can't access the Internet independently of your Super Hub. So you wouldn't be able to download on demand content.
    So its more a choice of do you want Wireless or Wired connectivity and take your pick.
    Did you install yourself? If not then I would have thought the VM person would have sorted this for you.
