Mouse pointer and menu appear during movies
Discussion in 'Computer Peripherals & Consumables' started by dUnKle, Jun 21, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    13,711
    +1,499
    Every 10 to 15 minutes the mouse pointer and menu bar (at top and bottom of screen) appear for no apparant reason
    Now I notice that the red light on the MCE remote reciver appears loads - be it typing on a keyboard or sneezing the light comes on - but it never seems to come on prior to the mouse pointer appearing
    Is this a knowjn problem - can it be configured not to happen
  2. dUnKle
    dUnKle
    Jan 1, 2001
    13,711
    +1,499
    anyone know answer to this
    seems to eb my mouse - are there any software tweaks to get the mouse to "switch off" from within mce ?
  3. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    Unfortunately this is a "feature". If the mouse is connected and moves MCE assumes you are using the mouse instead of the remote and pops up the menu bar
  4. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    do you have an optical mouse?
    i had a similar problem and it was due to the surface the mouse was on. For some reason the constantly flashing beam under the mouse would trigger what XP thought was movement every few minutes or so. I moved it to a soft material surface and the problem stopped.
    Slink
