mounting
Discussion in 'Projectors, Screens & Video Processors' started by reggieperrin, Jun 17, 2008.
  1. reggieperrin
    reggieperrin
    Apr 16, 2008
    17
    hi all
    just got in my optoma hd65 (and wow- bang for the buck is HUGE) now looking at screens
    due to length of room and height of ceiling (would involve massive long ceiling mount) im getting approx 3m wide 16:9 image - around 130" diagonal.
    now most of the cheaper screens i have seen seem to have the screw mounting holes at the end of the case. pretty inflexible if like me you have studwork walls
    could plasterboard screws hold up a screen of that size?
    ceiling hanging is a no-no as well i think again due to the height of the ceiling - would look a bit weird with 2m of chain hanging down!
  2. stevelup
    stevelup
    Aug 13, 2002
    6,606
    Swindon
    +1,144
    There are lots of screens with sliding brackets which you could align with the studs so have another shop around before committing to one.
    I wouldn't recommend plasterboard screws - those PJ screens are very heavy and they are subject to vibration when raising and lowering.
    Best compromise would be to fix a batten to the wall (screwed into the studs), and then attach your screen to that. It should be possible to do it discretely as the screen housing will hide your batten.
    Steve
  3. reggieperrin
    reggieperrin
    Apr 16, 2008
    17
    yeah i was thinking of batten, only problem is there is a large (~1m) drop back from the wall, and when it comes forward again that seems to be just plasterboard, no studs there.
    only studs i can find on the left would leave over a meter floating in mid air :)
