B
bergsey
Hi there, just working out how to mount my Z2 in my new home
The options available are either ceiling mount or mounting on the rear wall. I don't want to go the coffee table approach
In a ceiling mount configuration should the lense be in line with the top of the screen ? I read a post earlier which suggested for the Z2 the ideal vertical position is centred in the middle of the screen. For a ceiling mount this would probably make the projector way too low
Can someone confirm ?
PS: looking at projecting a 96" screen - distance from screen to rear wall is 5 metres. Height of ceiling is 10"
