Mounting to a concrete ceiling
Discussion in 'Projectors, Screens & Video Processors' started by kcw, Aug 16, 2004.
  1. kcw
    kcw
    Jan 10, 2003
    511
    london
    +8
    I've more or less decided to go back to a crt from lcd's which I just can't agree with.
    I need to have the projector ceiling mounted but have a concrete ceiling in my flat. I've seen it mentioned on a few websites that people have used anchor bolts. Does anyone have any experience of whether it's safe to use these and which size would be best for the job?
    Kenny
  2. BenC
    BenC
    Oct 15, 2002
    405
    London
    +6
    Hi Kenny,
    My Seleco SVP-400 hangs from a concrete ceiling. I used 4 x 14mm (or maybe 12mm??) anchor bolts, these use 8mm threaded rods I believe. If these anchors are installed correctly they will hold huge weights, certainly a 50kg - 75kg projector would cause no problem when hung on four of them.
    I posted pictures a while ago...
    Ah here you go: http://www.avforums.com/forums/showthread.php?t=55834
    Ben.
  3. kcw
    kcw
    Jan 10, 2003
    511
    london
    +8
    Thanks Ben, I'll give it a go then.
