Mounting Surround Bookshelf Speakers To PLASTERBOARD
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by EmissarY, Jan 12, 2005.
  1. EmissarY
    EmissarY
    Hiya All,
    Can anyone provide some tips please. I have a Mission M72i bookshelf speaker which weighs 7.6kg approx. Would I get away mounting this on a plasterboard wall? If not, how can I do it?
    Cheers 4 any input,
    EmissarY.
  2. dave741
    dave741
    If they have brackets (not aware of mission range) expanding rawlbolts will easily hold this. They are like a metal rawplug which expands because once you have inserted them in a plasterboard wall you tighten the bolt head to expand the support....then just undo bolt and fit bracket. (i know rubbish description but will work) Many years ago i held a pair of 12kg speakers + brackets with this method never had one problem
    hope this helps :smashin:
  3. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Check at the bottom of THIS page.
    edit: Or try to hit the wooden baton within the wall with woodscrews.
