Mounting solution for laptop in car required
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by keelby1, Jun 1, 2005.
  1. keelby1
    keelby1
    Dec 11, 2002
    1,189
    38
    Grimsby
    +14
    Has anyone any suggestions for mounting a laptop for viewing in the rear of a car?
  2. khalilk
    khalilk
    Feb 11, 2005
    23
    hey ...
    couple of questions .. do you require power for the laptop to be fed in from car ?
    would you want to use the car's existing speakers to out put the sound for your laptop application or its own speakers / headphone ?
    a quick and easy suggestion will be to use a coble of velcro straps and or perhaps a modified laptop carry case ...
    would you consider dismantelling it ?
    do you have an arm rest ? in the rear ..or a centre console
    seat pockets that you can use for storgae of the laptop....
    may be a fiber glass build but will have to be a bit on the big side to accomodate the laptop in the centre loosing valuable rear passenger leg room specially in the middle seat...
    good luck !
