Mounting Sky box ?
Discussion in 'Sky Digital TV Forum' started by balks, Nov 17, 2004.
  1. balks
    balks
    Hi guys,
    I would like to try and mount my Sky+ box to the underside of the top of a cabinet.
    I looked in B&Q just for simple "C" shape adjustable clamp style brackets but couldnt find anything would u believe!
    Anyone know where i could find these ?
    Failing that, I have looked online and found VCR mounting brackets like these..
    http://www.mghusa.com/Products/TV-Mounts/vm-104-1a.html
    http://www.classd-design.com/products/detail.asp?ProductId=347
    http://www.canford.co.uk/commerce/resources/catimages/large/90/9034.jpg
    The look almost right. But the problem is that they are all designed to hang underneath a tv bracket. So i dont know if they have holes along the top bar that i could use to put screws up into the cabinet.
    Anyone got any ideas please ?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Do Sky+ boxes get hot or have vents in the top like normal sky boxes?
    You will have a lot less cooling if you do this, depends on how low you mount it though.
  3. balks
    balks
    Mylo,
    Yeah, they have vents all along the top of the box.
    Hence i wanted to mount it with about 1" clearance from the top of the cabinet.
    In fact, i think that would allow better venting for the SKY+ box, since it is currently sitting right ontop of the tv (which gets very warm).
