Mounting screws ( m6 x l14 ) for LE32R41BD????
Discussion in 'Home Cinema Buying & Building' started by DJBIGJAY, Oct 25, 2005.
  1. DJBIGJAY
    DJBIGJAY
    I was wondering if anyone knew about the above screws ( M6 x L14 ) because i have brought a B Tech mounting bracket and adaptor plate and need to fit it to back of the samsung.
    I presume these screws do not come with the LCD or the bracket, or do they?
    If not a trip to B & Q is on the cards but they only do screw lengths of 12 or 16, no 14.
    Anyone else been in the same situation?
    cheers for any info.
  2. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    Im not sure about the L14 bit but my LE40R51B has 8 M6 holes on the back for the mount.
    I bought one of those frame brackets from ebay ( best way I can describe it!) and it came with M5 screws.
    I think the number refers to the size in mm but I might be wrong, I bought some M6 from my local fixings shop individually but they were too long but only today I was in my local B+Q and found the right length and were M6, a bag for £1.30.
    If you can only find them that are too long then you could cut them down or if they are only just too long then a couple of washers.
    You may already know but they are called "machine screws"
    Hope that helps
  3. thelurch
    thelurch
    Oct 4, 2005
    473
    +8
    sorry, L14 is obviously the length ! derrr, realised having just re read your post!
  4. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Just got a B-Tech tilt wall mount for my Samung 32" and it came with screws for the adapter plate!
  5. DJBIGJAY
    DJBIGJAY
    Cheers for info. :smashin:
    Yes L is the length and i assume M is the diameter of screw thread.
    Yeah knew they were machine screws, so off to B and Q it is then for screws and washers.
