K
kevtotty
Hi there
As a result of all the excellent installations I have seen on this forum, I have decided not only to by a Pioneer Plasma but also to mount it into a false recess on a chimney breast.
Question (possibly silly!!) is - how do you attach it to the wall mount in a recess - is this possible??? or do you build up the wall with stud/plasterboard around the screen (meaning it will be hard to remove at a later date?).
Any comments?
Kevin
Any comments?
Kevin
