Mounting Satellites High
Discussion in 'Home Cinema Speakers' started by nheather, Sep 29, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    17,452
    167
    Horsham, West Sussex
    +6,806
    I'd appreciate some advice about speaker mounting.
    I'm not a fanatical audophile but I am looking for a reasonably nice sound for my home cinema.
    Aesthetics and budget mean that I'm looking at a small speaker system like the Kef 2005.
    The plasma will be wall mounted so that it is centred at eye level when sat down.
    The centre will be below the plasma on top of an AV unit and the sateillites will be mounted at the corners of the square room just below ceiling level.
    This means that fronts will be about 1.7M higher than the centre.
    I know this is not ideal but what impact will it have. Is it something that only an experienced ear would notice.
    I've considered mounting the sats lower or using stands but my wife isn't too impressed with how that would look.
    Any thoughts?
    Cheers,
    Nigel
  2. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,796
    Bexhill on Sea
    +239
    Nigel
    I have had to mount my front speakers quite high due to lack of space each side of the telly for speaker stands. They are not quite as high as yours by the sounds of it, but are still a fair bit above the television.
    Not the ideal solution, but they sound really good.
    I use these fella's by the way, and am very impressed with the sound quality.
    http://www.superfi.co.uk/index.cfm/page/moreinfo-1.cfm/Product_ID/2298
    HTH
    Rob
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    You may have problems with any sounds that pan away from the centre as the difference in height between the centre and the main pair is quite considerable.
    I know it's a cliche but you should try it out first before making any permanent installation as I don't thibnk that you would be happy - audiophile or not.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    If you want to see what the sat speakers will look like mounted close to a plasma then take a look in This Thread as there are loads of sub sat packages pictured. It may help to show SWMBO how good it can look :thumbsup:
    Mark.
  5. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,796
    Bexhill on Sea
    +239
    Dear Deidre
    Oh how I wish I had that much room........:( :(
    If I attached a piccie of my set up you would see the problem I have.
    The only wall in my living room that would enable me to set my system out like those would necessitate me having to move a door to fit a settee in :thumbsdow
    I would dearly love my speakers nearer the TV or lower on the wall but I've tried everything to no avail.
    Dejected of Bexhill on Sea
    :D :D :D
