Mounting Samsung 46" on plasterboard with the 'new' type bracket
Discussion in 'Home Cinema Buying & Building' started by pbb76, Jun 16, 2009.
  1. pbb76
    pbb76
    May 29, 2007
    7,332
    Colchester, Essex
    +1,509
  2. BradG
    BradG
    Nov 24, 2008
    104
    blackpool
    +6
    just be sure to mount them on the joists!
  3. pbb76
    pbb76
    May 29, 2007
    7,332
    Colchester, Essex
    +1,509
    It doesnt say that in the instructions - neither does it show it in any vids I've seen?
    Have you actually done this as the brackets comes with special fixings for plasterboard...
  4. anauJ
    anauJ
    Jun 18, 2009
    5
    Honestly? Give it back, get the cheapest bracket you can get, if the plaster is dry and 2cm thick thats more than you need!
    Get 8-10 Plaster screws and a braket (I just installed this one today: Fits Philips LG Pioneer TV WALL BRACKET MOUNT 32 37 50 on eBay (end time 14-Jul-09 15:14:50 BST) for £22 delivered) Its think, easy to mount and forget about the wooden frame, I couldnt find mine because it didnt have any (wall was a diving one, not that great of a wall and empty).
    Hanged my 50" Lg + the weight of me+ my gf on each side to test it was ok, and the tv still there.
    My advice? Spend the £200 on something else , send them back :smashin:
