Mounting positions for the Panny 37?
Discussion in 'Home Cinema Buying & Building' started by rikman808, Feb 13, 2009.
  1. rikman808
    rikman808
    Aug 10, 2007
    25
    I want to buy a bracket for my Panasonic TH37PX70 to stop my 20 month old paintinig the screen with yogurt or using the glass as a train track for his Thomas the Tank engine!!
    I'm in work and can't check the telly now so can anyone please advise on the distance between the mounting points on this specific model or the VESA rating?
    I want to order one and I want to order it today before it meets it's TV maker at the hands of my little'un.
    If you care to suggest a particular bracket it needs to be a cantilever bracket with turn and tilt as teh TV will be mounted in a right hand alcove and needs to come out about 60-70cm.
    Any advice is greatly appreciated.
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    This TV has a 200x100 fixing, however with a TV of this size you need a universal type bracket anyway to spread the fixing points on the wall.
    We have this bracket available which would fit your TV and give you 576mm of extension;
    M-Form - 32" to 52" Articulated Universal LCD/Plasma Bracke
    Hope this helps.
    Regards
    Graham
