Ewan154
- Joined
- Aug 2, 2005
- Messages
- 2,083
- Reaction score
- 88
- Points
- 809
I tried to put my projector up at the very top of the wall. Problem is everything went wrong
I drilled 2, 10mm holes at the very top of the wall. I thought the plasterboard would be hollow, but to my surprise it was hollow for about an 1 inch then there was very hard wood.
I cut a bit off a super toggle plasterboard plug and put them in the holes, now here is where every thing went wrong
Went I put the screws in the plug moved about.
In the end, I called it a day and filled in the holes.
What should i use for the bit at the top of the wall that is hollow for about an inch? further down the wall it is hollow.
This is the mount I'm using
PM103 Universal Projector Wall Mount Bracket Telescopic: Amazon.co.uk: Electronics
Any advice/suggestion?
I would like to try and use the holes that I have already drilled and filled in.
(if I can)
(if I can)
— As an Amazon Associate, AVForums earns from qualifying purchases —
