Mounting my PW6 on the wall
Discussion in 'Home Cinema Buying & Building' started by Gof, Sep 1, 2004.
  1. Gof
    Gof
    Aug 30, 2004
    883
    28
    +25
    Any ideas on thh best way to wall mount my PW6 this weekend when it arrives!
    Lookign to wall mount - not bothered about tilting or anything just looking for a secure fix to a wall.
    Happy(ish) to do myself unless anyone can recommend any fitters in Derby/Nottingham who may be affordable to hide cables - otherwise I'll trunk them.
    Open to opinions on mounts and info i need to know before mountign on wall armed with a drill and a spirit level!
    cheers.
  2. John
    John
    Dec 13, 2002
    11,396
    +3,025
    Try doing a search, millions of posts on mounting.(and fixing plasmas to walls :p )
    But make sure you know what type of wall your mounting it to ,and use the correct fixings .
    Good luck :smashin:
    john
  3. Gof
    Gof
    Aug 30, 2004
    883
    28
    +25
    cheers
  4. MrSimba
    MrSimba
  5. Gof
    Gof
    Aug 30, 2004
    883
    28
    +25
    That looks well sweet. I bought a Richer Sounds general one up today but am tempted to take it back - anyone used the RS one before?
