Mounting my LG flush - which bracket?
Discussion in 'Home Cinema Buying & Building' started by thecount, May 7, 2004.
  1. thecount
    thecount
    Mar 15, 2004
    173
    Just got my 20 RZLA70 LCD Screen delivered and am desperate to mount it as close to the wall as possible and I don't need to tilt it either. Anyone got any reccomendations where I can get such a bracket for doing this. The holes on the back are about 10cm apart.
    Thank You
  2. thecount
    thecount
    Mar 15, 2004
    173
    Ok, sorry, just been searching through some past messages and found one which reccomends the BT7511 which only sits 20mm from the wall which is perfect. That'll do nicely. Just got it from http://www.keene.co.uk - £19.99
