Matt
Established Member
My living room is being replasters so i am taking the opertunity to get my Mission M7SD rear speakers mounted where i want them I am going to be putting the cable in the wall and then connecting them to the speakers.
Because of the low profile i cannot use banana plugs so will either connect them directly or use spades (never tried them before).
I will probably use some CAT5 cable for the rears thought not sure whether a single run or 3 plaited ones.
How can i make sure that the cables will not dissapear down the hole in the wall never to be seen again? I'll probably use a blanking plate for the cable exit.
Is the best way of mounting the speakers just a pair of screws in the eyelets?
