mounting height
Discussion in 'Home Cinema Buying & Building' started by dapex, Feb 28, 2005.
  1. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    Hi all, just started seriously looking into getting a plasma and I wondered why height seems to be the average for a wall mounted screen, the reason I ask is that the wife wants it above the fire place, but our fireplace is pretty high (will measure it this evening) and i reckon this will be aproblem....
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    if you search the forums for fireplace and viewing angle I think you will find quite a few threads on this.
  3. symphara
    symphara
    Jul 15, 2004
    332
    Switzerland
    +61
    I find that watching anything placed higher than eyeline for a long time (and watching a movie is a long time) gives me a sore neck and general discomfort. I feel like going to see a blockbuster in the cinema the very first release day, you know when the only available seats are in rows 1 or 2. Imagine experiencing that every time you watch a movie or TV!
    So I'd place the plasma fairly low. Having said that, a lot of folks here appear to have gone for the fireplace option with tilting brackets. Best idea - before buying get a cardboard cut with the same dimensions of the plasma and try different positions. See if you last for a couple of hours looking at it, when mounting above the fireplace :eek:
    One last thing - if you do mount it above the fireplace it would be a bad idea to keep using the fireplace, since you might end up damaging the plasma. And if you don't use it again, what's the use of the fireplace? Can you get rid of it and put the plasma instead?
  4. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    I asked this same question in a previous thread. It seems to be very much a matter of taste. I ended up putting mine (accidentally) about 6 ins higher than I would have liked, which was about 12 ins than ideal due to fixtures in the wall. So all in all it's a little higher than planned. It's fine. I'm used to it being 'up' rather than on the cabinet. It does encourage me to slouch on my sofa, but when was that a bad thing. Haven't suffered from the anticipated neck or eyes strain at all.
  5. Deaves
    Deaves
    Feb 5, 2005
    43
    I Think The Problem Is When The Plasma Is Not On People Think Of It The Way They Would A Picture In A Frame And Expect It To Be Quite High, But When You Are Watching It I Personally Think The Lower The Better.
  6. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    Mine (when I finally get it) will be on the floor, leaning against the wall (held in place at the back, of course)... The top of a 42" plasma will be pretty much at the eyeline then anyway.
  7. John
    John
    Dec 13, 2002
    11,683
    +3,350
    Make your self a cardboard template .Stick it on the wall , sit in your chair.If it looks good to you , :thumbsup: .Template method never fails
    Atb
    John
  8. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    cheers all, dont suppose anyone can give me measurments for a 42" panyy so i can make my template?
  9. Drd
    Drd
    Jan 22, 2005
    1,904
    Approaching the doghouse at great speed
    +301
    102 x 61 cm
  10. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    Eye level is the correct level.
  11. dann
    dann
    Aug 25, 2003
    134
    Hi dapex
    Just to add, I have just got a 42" Viera and have placed it on the wall before chasing the walls out, we have had it on the wall for about 3 weeks now & have moved it up once because we felt eye level was too low, It is now at 140 cm. & we are happy now.
    Point is, If you dont mined extra work, hang the plasma in a few positions to get it spot on too your own requirements.
    Dan
  12. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
    94cm from the floor for my 42" panny...wouldnt really like it any higher as i am only 10-12ft from screen.
    JJ
  13. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    Of course the problems start if you're 6'6",SWMBO's 5 foot nothing,and then there's the kids.Does anyone make a multilevel 5 seater settee? :D
    Regards
    Ian
  14. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    measured the fireplace and from floor to bottom of plasma would be 4ft. seems a bit high to me but Iwill still make the template and see. I do have a 4yr old to think of as well. Failing that, anyone know how it is to remove a wooden fire surround and replace with a smaller one??
  15. Nostromo426
    Nostromo426
    Nov 16, 2004
    28
    Essex
    Have had my 50" PHD7 for 3 weeks now - from floor to bottom of plasma = 48"
    viewing distance 12' - no problems with neck/eye strain
    Looks nice too
  16. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    I also was planning on having mine on the mantelpiece, but when in place it looked very wrong - I went for something a bit different, working out ok for me...
  17. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Eye level works great for me...
  18. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    I did the cardboard plasma telly thing. Made a fake Veira and tried it at different heights.
    Finally settled on the same height as the screen would be if it were on an official Panasonic floor stand. Very happy.
  19. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    Nice - very red,
    What's that thing on the floor in the middle?
  20. retro21
    retro21
    Jan 25, 2005
    149
    London
    +4
    Looks like an X-Box to me !?!
  21. Rambles
    Rambles
    Jul 14, 2004
    10,445
    167
    UK
    +2,154
    Didn't know they did them in silver - very modern ;)
  22. Drd
    Drd
    Jan 22, 2005
    1,904
    +301
    Love the dog's bed,puts my mutt's pad to shame!
  23. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Sherrie my pussycat isn't very happy! :mad: But she's glad you like her bed! :thumbsup:
    Crystal X-Box a limited edition. Bought it around Christmas time.
  24. symphara
    symphara
    Jul 15, 2004
    332
    Switzerland
    +61
    very nice setup... :smashin:
  25. Turkey Shooter
    Turkey Shooter
    Does anyone know of a wall mount that allows some adjustment to the height of the unit. I can see all sorts that swing and tilt but nothing that slides up and down.
    I too think the unit should be lower for viewing but as stated earlier it will look less conspicuous higher up when switched off.
