Can anyone help with some advise to ceiling mounting a Tosh Tlp-Mt3 and how many threaded holes are there on the base cos I only saw 2 is there another 2 under the round rubber feet cheers
The MT1 (same case) has two screw holes on the "bottom"(towards the front), and two screw holes at the "back"(rear facing etc) of the projector. I was suprised how small the screwholes where. You do not have to remove the rubber feet!.
