Question mounting a ue55hu7500 on a questionable wall.
Eightshot
so the wall i want to mount the TV onto is a loose brick wall (no mortar) sandwiched between plaster board. it is the dividing wall between my living room and dinning room. with the TV going on the living room side.
My current thinking is to mount a piece of thin ply to the wall in the dinning room then bolt the TV wall bracket all the way through from the living room.
Was just wondering if anyone could recommend something that was a little cleaner?
the TV weighs in at 17.8kg + the mount
appreciate any help anyone can offer.
