mounting a TV in wall?
Discussion in 'General TV Discussions Forum' started by richard plumb, Oct 15, 2003.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,450
    Windsor
    +1,044
    I'm probably crazy, but is it possible to install a widescreen CRT in a wall (Chimney breast to be precise)?
    Can any ventilation issues be overcome? I thought it might be a cheaper way to get the flat screen effect (which would go in the same place anyway)
    Looking at a 32" CRT by the way.
  2. Johndm
    Johndm
    Jan 25, 2003
    1,819
    Bedford UK
    +66
    My Panny 32" is about 21 inches deep, so you wouldn't have much chimerney left, PLUS, how would you get the dead seagulls out of it?? PLUS when it goes wrong, you will have to parachute an engineer down the chimerney.....
    I'm crazy too............
