Mounting a TH46PZ80 onto an Ikea Benno cabinet?
DazzlaUK
Member252055
The way to do it is to get yourself a universal wall bracket; M-Form - 32" to 50" Universal LCD/Plasma Bracket and fix it to the back board using through-holes and bolts with nuts. Basically drill your fixing points all the way through the board and use nuts, bolts and washers rather than relying on woodscrews in MDF. This way the weight is supported by the structure of the MDF rather than the fibre inside it's skin.
If you go for our bracket I'll include the bolts and nuts you need for the install.
All our brackets benefit from Free Delivery and our unique G-Fit Guarantee.
Regards
Graham
Hope this helps
Regards
Graham
