Mounting a projector on the ceiling help
Discussion in 'Projectors, Screens & Video Processors' started by Chibouk, May 28, 2004.
  1. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    I'm going to mount my projector on the ceiling next week and I wondered if there was a clever way to work out how long a pole I need to order.
    The ceilings in our house are very high and a normal length mount won't do it, so I'm going to order one with an extension pole. The thing is, I know the projector will be mounted upside-down, but does that affect the way the image is projected? How do I work out how high (or low) I need to mount the projector?
    Any help would be appreciated. :)
  2. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Does your projector have lens shift or keystone correction? If it does, the pole mount length shoudn't be much of an issue.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    If no lens shift (etc) then in general, projectors are designed so that when mounted upside down, the centre of the lens should be level with the TOP of the screen. However, your projector manual will probably confirm this, and may even offer an illustration.
  4. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    I've looked in the manual and it does indeed show a little illustration of the way the 'beam' is projected. Thanks for pointing that out. :D
    I have a Panasonic AE200, which has vertical (I think) keystone correction. I wanted to avoid using this, however, as I heard that it dramatically affects the picture quality. Is this right?
    Thanks for the help, it's always appreciated. :)
  5. Zone
    Zone
    Jun 24, 2001
    6,775
    Barnsley
    +2,507
    I have the 300 and managed to set it up square on to the screen which is recommended.
    I did have a play with keystone correction though, just to see what effects it had on the image and to my eyes I couldn't see any noticeable degradation in picture quality.
  6. LV426
    LV426
    Jul 14, 2000
    13,529
    +6,000
    Very small amounts of keystone correction have a minimal effect, but an effect nevertheless. Best avoided, if you can.
    So......
    Laterally, the centre of the projector LENS should be central to the screen.
    Vertically, the centre of the projector LENS should be level with the top of the screen.
  7. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    Thanks once again for your help everyone. :smashin:
    All I need to do now is order the mount and get it all fixed up. :)
