Mounting a flatscreen LCD TV above a fireplace
THERINGMASTA
I'm about to buy a 40" Samsung LE40F71BX High Definition 1080p LCD TV. I want to mount this onto the wall above the fireplace. However the fireplace will often be in use.
Will this be a fire hazard?
Will the heat interfere with or damage my tv?
If I chased into the wall to hide wires, will this cause any risks?
Thanks in advance for any advice
deagle
Established Member
Common sense surely applies here and nobody can give you a definitive answer but I would suggest that you light a good fire (when the weather cools down a little) and just see how hot the fireplace gets in the location where you are siting the TV.
There is also the risk of smoke particles being drawn to the screen - long term effects are a bit difficult to guess. Suggest that if you do try this then don't do it with something too expensive !
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
