Mount for Panasonic P50U20B
y2viks
I'm after a wall mount for a Panasonic P50U20B. I'd like it to tilt by a few degrees and also swivel by a small amount.
Any recommendations? I've checked a few sites and I can't really see the differences between the £50 ones and the £150 ones.
I'd ideally like to have a built in spirit level but it's not essential
Member252055
The difference between the prices is basically quality, same as anything else.
With a 50" TV you need to make sure that there's no sag or twist in the bracket as this will show up once the bracket is tilted or swivelled. In this case a double arms type bracket is best. These tend to be more expensive due to the extra material and fittings.
Our recommended bracket for this TV would be this one;
M-Form - 37" to 52" Free Motion Cantilever Bracket (Black)
It's at the top end of your cost spectrum but you do get the advantage of it being just 74mm deep when pushed back.
Hope this helps.
Regards
Graham
