Mount 42" Panasonic onto Thermalite Wall
Manny1972
I am looking for guidance on how to mount a 42" Panasonic plasma onto a Thermalite wall. Basically I need info on the specific fixings that i should use to provide the strongest hold for the TV. I have read people using Rigifix, resin, bolts so am very confused as to what to use. The TV will go on a chimney that has been built using Thermalite blocks which have then been bonded and skimmed.
Thank you
