Motorola V3 screen problem
Discussion in 'Mobile Phones Forum' started by Monkey99, Jul 12, 2005.
Tags:
  1. Monkey99
    Monkey99
    Apr 10, 2005
    26
    4
    The Spa
    Don't know if anyone can help.. have a V3 and all was fine! But this morning when the alrm went off I pressed snooze, as usual! But when I got up I noticed the screen had gone completely white, and the phone was unresponsive - only way I could get it to switch off was to pull the battery - when I did this and switched it back on the screens are both blank and showing no display - is responding on to the V3 tool and seem to be able to switch it on and off. Still makes the right noises!
    Anyone any idea of the problem or is it more terminal - not sure if its still under warranty at the minute :confused:
  2. Monkey99
    Monkey99
    Apr 10, 2005
    26
    4
    The Spa
    Well the phone itself does definitely work.. I have manged to get it onto the network, made and recieved calls! So it is defintely just the screen that doesnt work - any opinions on whether replacing this with one off e-bay should do the trick or is it possibly something else?
  3. yaserk99
    yaserk99
    Dec 30, 2004
    9
    West Yorkshire
    **** Phone
  4. rimmep1
    rimmep1
    Jun 19, 2004
    213
    28
    +40
    It sounds like the LCD connecting ribbon has detached. Not all that common, but have had experience of this myself on a V600. If I were you, I'd check if you've still got some warranty left on it. I wouldn't recommend attempting to repair it yourself as the ribbon can easily become trapped and torn if the handset is incorrectly reassembled.
    Moto UK are usually quite good at dealing with warranty claims so you shouldn't have any problems. :)
