Motorola V3 - Phonebook help please
Discussion in 'Mobile Phones Forum' started by Darkgedi, Feb 16, 2005.
Tags:
  1. Darkgedi
    Darkgedi
    Ok, so I have managed to get my 400 numbers across from my old Nokia to the V3 via my Mac. It's a long list and I can't figure out how to select a number other than scrolloing down one at a time. I know I'm tired and missing the obvious. How do I do this?
    I now think the numbers have gone across is a format which the phone cannot search on. `if `i manually enter a number the name looks slightly offset in the list and can be searched on. Any ideas?
    Darkgedi.
  2. stulou
    stulou
    Mar 14, 2005
    182
    Southampton
    +21
    I have the V3 and love it but it does have one major flaw.
    You can only search by the 1st letter of any entry, and then you have to scroll down one by one.
    Hope this helps.
    Regards,
    Stulou
  3. EnigmaCode
    EnigmaCode
    Dec 16, 2004
    265
    +21
    as for the latter part, no you don't.
    phonebook, press menukey, setup, view primary numbers.
    to view all your numbers from the same person, use the left and right joystick.
