Motorola V3 battery life problem
Discussion in 'Mobile Phones Forum' started by marcm, Sep 4, 2005.
Tags:
  1. marcm
    marcm
    Have found an annoying problem with my wifes phone. Battery appears to charge and then after 1 hour of virtually no use, jump down. A full charge lasting upto 6 hrs. Have bought a new battery, which has not fixed the problem. Has anyone found the same? The phone is 9 months old. Or should I try and send it back under warranty?Thanks
  2. wolfy180
    wolfy180
    It seems to be a common problem with Motorola`s at the moment across all models as far as I can gather
