Motorola ROKR E1 Vibrate question.
M
matty b
Does anyone know if you can set the E1 to vibrate whilst ringing as well ? Can't seem to find how. It will vibrate then ring but stops vibrating when ringtone starts up, or it will just vibrate only - can't get it to do both ! :confused:
C
clonmult
I think this is just the way it is designed, pretty much normal moto.
I seem to remember something about a vibe synch option which may be what you want; I'll have to check with our E398 later on.
