Motorola Brick mobile
Discussion in 'Mobile Phones Forum' started by milgo, Sep 19, 2003.
Tags:
  1. milgo
    milgo
    Does anyone know if it is possible for one of the old motorola brick phones (8500x, 8800x etc) to work with current sim cards and networks?
  2. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    IIRC, they did not use sim cards, and worked on the now defunct analogue network
    However, you could probably fit 4 or 5 current mobiles within the motorolas casing, if you wanted to do some adapting!
    woody
