Please bare with me here.....
I have a motorised 1.2m dish which is connected to a dm500 at the moment.
I want to move the dm upstairs and hopefully pop a PCI card into my HTPC which is in main room.
First question is what card can people recommend me that will take HD signals as well as all the SD ones.
Next question is how easy is it to install ? My dish has just been realligned so it is bang on. How do I get the PCI card to know what satellite it is pointing at? I hope thats a clear question
Is there any particular card that works better with cccam software? Its a windows based pc but I know I can set up the cccam on there using a VM.
Thanks for any help.
