Motorcycle Diaries UK BD
Discussion in 'Blu-ray & DVD discs' started by overlok, Jun 16, 2009.
  1. overlok
    overlok
    Hi. ¿ Are the subtitles burnt into the image or are optional?
    I believe that the dvd comes with burnt subtitles and the HD-DVD not, but I do not find information of the BD.
    ¿ Are the image and sound good ?
  2. kmark40
    kmark40
    Jul 6, 2006
    1,354
    Antipodes
    +42
    i have the hddvd and the quality on that looks worse than most newer dvd's. cracking film though :smashin:
  3. pRot3us
    pRot3us
    Oct 20, 2004
    6,705
    +5,477
    Agreed, if the BD is the same transfer you should avoid like the plague.
