Motion Judder when playing Xvid on 50" plasma
smooth-op
Hello
I am not sure if any one else is experiancing this
i built my HTPC i am quite experinced with PC Hardware
components are
Intel I7 2600k socket 1155 (3.2 ghz @4ghz)
Z68 chipset Motherboard (Asus)
16Gb ddr3 (Corsair vengance 1866mhz)
750gb caviar black hard drive
XFX Black edition HD6870 Ati grapics card
the HTPC is connected to Onkyo SR706 reciever via a 1.4a cerified hdmi cable (this is irrelevent as my tv or amp does not support 3d but i do want it to bitsream DTS-HD Master audio which works fine)
THE PROBLEM
i seem to get motion judder when playing standard resoulution xvid video formats. no matter what player i use its still the same. i have tried using lower resolution but my plasma is only HD ready so 720p is max. and the above hardware should easily play low reolution xvid. i also get this problem with watching bbc iplayer. but because this is web based i didnt weant to use this as a eg..
All HD Formats work perfectly with out motion judder
Players used
VLC player
Media player (mircosoft)
Zoom player
codecs tried
Cole2k advanced
Core 2 professional
divex codec pack
I have tried updating to the latest drivers for my gfx card. currently on 11.12
i have tried fresh instalation of windows 7 (64bit) more times then i try to remember
i was wondering if any one else out there has the same problem and fixed it?
Thank you
LG CX 4K OLED TV Review: The best TV of 2020?
