Motherboards with S/PDIF optical out?
Discussion in 'Computer Components' started by ozdick, Jan 14, 2003.
  1. ozdick
    ozdick
    Are there any motherboards you would recommend for a HTPC that have an inbuilt S/PDIF optical out? (Also preferably with inbuilt LAN)
    Richard
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Asus A7V8X, onboard spdif on a seperate bracket with a proper coaxial socket and a 10/100/1000 lan socket, cheap now (£65+VAT) as a replacement has just come out, (unlocks the multiplyer on newer athlons if your interested).
  3. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    The Intel D845PEBT2 has both coax and optical outs which work very well with Theatertek/Sonic Cineplayer
  4. Turl
    Turl
    Apologies if this is a question with an obvious answer but will Mobo's with SPDIF or Coax out sockets output Dolby Digital and DTS to an AV amp?.
    If so I am correct in assuming that DD EX and DTS-ES will also be output and therefore decoded by the amp?.
    The reason I ask is that I am thinking about building my next PC without a dedicated soundcard.
    Thanks,
    Turl
  5. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    I think it depends on the chipset used, certainly the Cmedia variety appears to be sucessful at DD and DTS as well as straight stereo with WMP.
  6. RecoilUK
    RecoilUK
    I have the ASUS A7N8X Deluxe which includes the soundstorm technology. It has a coaxial output on the motherboard and outputs dolby digital straight from the disk, when used with PowerDVD XP 4.0. I would imagine it would pass through DTS and all the other formats to, but I havnt got any DTS disks to test.
    But the real bonus for this motherboard is that it will encode all sounds (games,windows etc) into dolby digital.
    Mines hooked up to a set of Creative Digital 5700 speakers, and I have to say, for the money I spent it sounds awesome.
    Hope that helps.
  7. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    512
    16
    Aylesbury...where the Ducks live!!
    the abit IT7 max boards have an optical hook up
  8. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    My abit NF7-S has an optical out, i've no idea what its like though as i haven't used it yet.
    Spunky
