Quantcast
Motherboards with DTS output
sapper
Are there any mother boards which output DTS in the sPDIF Digital output?
If so, are they any good?
Just curious!
Comer
I thought that any mainboard/soundcard that passes Dolby Digital through spdif will also pass DTS???
<<ERROR>>
I am pretty sure that the nForce motherboards for Athlon XP processors will encode and output Dolby Digital, on the optical port, from any audio source you use, even (especially) games. I believe that they are the only audio chip that is capable of doing this, so you can hook up your PC to an existing audio receiver and use it for digital surround sound on both games and film.
Also, as Comer said, any sound device with an optical output can pass through S/PDIF audio on an optical port (regardless of what type it is - Dolby, Dolby EX, DTS, DTS ES, etc.)
F
fufna
Yep, I run a Winfast Nforce motherboard and this decodes raw data straight from the disc and spits it out of the coax perfectly
