Motherboard with DVI out
Discussion in 'Computer Components' started by cwinson, Mar 16, 2003.
  1. cwinson
    cwinson
    Nov 11, 2002
    76
    London
    Has anyone come across a motherboard with in-built DVI out ?
    I'm thinking of building an HTPC which will mainly be used for DVD playback and de-interlacing/scaling a Sky+ signal into my PJ (TW100). For these purposes, I won't be needing all the 3D capabilities of the top-notch graphics cards (e.g. Radeon), just the DVI out. Is this a correct assumption ?
    Chris
  2. Kramer
    Kramer
    No, not really. The graphics card is largely responsible for all the scaling/video processing etc...Everything you see goes through your graphics card.
    So a good graphics card is a prerequesite. Radeon - obvious choice.
    Software acceleration isn't as dependent on your GPU, but hardware acceleration is infinitely better.
    Re: DVI.
    I've never encountered a DVI equiped mainboard. Again, a Radeon card is recommended.
  3. amordue
    amordue
    Nov 13, 2002
    101
    Edinburgh
    The DFI NB76-EA (P4 motherboard using integrated Intel845 for graphics) comes with DVI-out on a seperated card that goes into the agp slot. As kramer said its most likely going to be very poor at hardware overlay scaling whcih is what you'd want for playing dvds and video captured material.
