Motherboard/Processor
Discussion in 'Computer Components' started by sapper, Oct 21, 2005.
  1. sapper
    sapper
    Jul 20, 2000
    2,258
    Southgate, North London
    +145
    An old MESH AMD Athlon 1900XP machine died last night, cannot even boot up in safe mode. Gut feeling is the hard drive has died.
    Yes I could replace the hard drive, but I am contemplating building a repalcement machine.
    Anyone like to suggest a motherboard and processor combination. It is for the study, and so whislt soem media applications will be used, it is primarily as a working PC. Only request is that i can set up a RAID array for data storage if I chose to.
    Any comments, suggestions?
    Adrian
  2. OneEleven
    OneEleven
    MSI RS480 or EQS M56K9 with a S939 3000+
    Both have onboard PCIExpress x300, so you won't have to think about a gfx card just yet either.
  3. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    I just built a very nice system for penuts based on
    Antec Minuet II
    ASRock KNF4G-SATA2
    Athlon 64 Sempron 3100+
    Corsair Value Select PC3200
    WD SATA 80GB HD
    It was very cheap to make the whole things and it worked well. My only issue in building was a shorting between the case motherboard, but some paper/silicone washers fixed that (less hassle than returning).
    I picked the core parts up from microdirect, though eBuyer was similar.
    The final system looks very nice, is really quiet (supports AMD Cool n Quiet) . The VGA ia built in and is similar to geforce 6200 (shared video memory).
    Rajiv
  4. sapper
    sapper
    Jul 20, 2000
    2,258
    +145
    Since I have a 300 GB Maxtor Diamond 10 hard drive that I have recently purchased, It needs to be IDe compatable.
    What is the advantage of a SATA drive over a IDE hard drive?
    If I had a motherbaord which had a SATA drive, can I convert the maxtor diamond 10 into a SATA drive ??
    I am sure I have seen conversion kits soem where
    Adrian
  5. Deleted member 92943
    My system about a year ago cost about £1,500 but now can be picket up for about £1,000
    Ausus A8V Motherboard
    AMD 3500 Processor
    1GB Ram
    Geforce 6800gt 256mb Graphics Card
    2x Maxator Hard Drives
    DVD-RW (Dual Layered)
    I must change my Asus IceStar Processor Fan as it sound like a plane if flying past. They siad it would make my PC Silent. It might be a case of changing the power supply aswell
  6. OneEleven
    OneEleven
    In this setup , the only advantage would be the nice thin cables SATA use.
    All motherboards on the market at the moment still have IDE connections AFAIK
  7. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    sata are now a bit cheaper at the large capacity >160GB
    The board I mentioned above has 1 IDE so it would not be good if reusing old drives,
    but most have 2IDE 2SATA so its up to you.
    Rajiv
